Video thumbnail for How To Lay Laminate Flooring
Jul 18, 2022
With the help of Foundations Up Construction, DIY Doctor explains how to lay Laminate Flooring, including all the materials and tools needed to do so. Although this video is titled "Laminate Flooring", our carpenter is laying Engineered Timber Flooring, however, he has assured that the process is exactly the same regardless of the type of flooring being laid. If you would like a little more information on laying laminate flooring then see our how-to porject here: https://www.diydoctor.org.uk/projects/floor_laminates.htm
#Hobbies & Leisure #Home Improvement #Flooring
