Video thumbnail for Waste pipe compression joints
Oct 20, 2023
How to put a 32mm or 40mm plastic waste pipe compression joint together. This video works for all plastic waste compression joints from the bath, basin, sink or any other location where a waste pipe is required. Plastic wate pipes are usually used to take water away from the kitchen and bathroom where the waste pipe is then connected to the soil and bent pipe or sometimes directly to the main swere via an inspection chamber. More help with compression joints can be found here: https://www.diydoctor.org.uk/projects/compressionwaste.htm
View Video Transcript
#Plastics & Polymers #Home Improvement #Plumbing
